Configure new passwords for each access level, or change the logon or password for the different access levels of the system to prevent unauthorized access. After you receive the switch, use default passwords to initially access CLI. If you use Simple Network Management Protocol version 3 (SNMPv3), you can change passwords in encrypted format.
  1. In the navigation pane, expandConfiguration > Security > Control Path.
  2. Select General.
  3. Select the CLI tab.
  4. Specify the username and password for the appropriate access level.
  5. Select Apply.
CLI Field Descriptions
The following table defines parameters for the CLI tab.
Name
Description
RWAUserName
Specifies the user name for the read-write-all CLI account.
RWAPassword
Specifies the password for the read-write-all CLI account.
RWEnable
Activates the read-write access. The default is enabled.
RWUserName
Specifies the user name for the read-write CLI account.
RWPassword
Specifies the password for the read-write CLI account.
RWL3Enable
Activates the read-write Layer 3 access. The default is enabled.
RWL3UserName
Specifies the user name for the Layer 3 read-write CLI account.
RWL3Password
Specifies the password for the Layer 3 read-write CLI account.
RWL2Enable
Activates the read-write Layer 2 access. The default is enabled.
RWL2UserName
Specifies the user name for the Layer 2 read-write CLI account.
RWL2Password
Specifies the password for the Layer 2 read-write CLI account.
RWL1Enable
Activates the read-write Layer 1 access. The default is enabled.
RWL1UserName
Specifies the user name for the Layer 1 read-write CLI account.
RWL1Password
Specifies the password for the Layer 1 read-write CLI account.
ROEnable
Activates the read-only CLI account. The default is enabled.
ROUserName
Specifies the user name for the read-only CLI account.
ROPassword
Specifies the password for the read-only CLI account.
MaxTelnetSessions
Specifies the maximum number of concurrent Telnet sessions in a range from 0–8. The default is 8.
Timeout
Specifies the number of seconds of inactivity for a Telnet before the system initiates automatic timeout and disconnect, expressed in a range from 30–65535. The default is 900 seconds.
NumAccessViolations
Indicates the number of CLI access violations detected by the system. This variable is a read-only field.
CustomBannerText
Specifies the text message that is displayed to users on the CLI before authentication. The message can be company information, such as company name and contact, or a warning message for the users of CLI.
With character limitation from 1-1800, the text box displays 79 characters per line.
CustomBannerEnable
Specifies whether custom logon banner is enabled or disabled. The default is enabled.
